Checking slide change
Hello everyone,
For a program I need to know when the slide is changed by the user of the program.
I tried several things, but I can't fix it. Is there a property node, or something else, who can check if the slider has changed or not?
Thanks for all replies in advance,
Bjorn
(2,966 Views)
Hi Bjorn,
use an event structure with a "value change"-event for that slider...
(2,962 Views)
Hi Bjorn,
If you want to learn more about event structures here is a brief introduction:
https://www.ni.com/en/support/documentation/supplemental/06/event-driven-programming-in-labview.html
Reagrds,
Henk
(2,932 Views)
