Chirp Signal Generation using For Loop
Is it possible for me to be ale to produce a chirp signal using for loop?
I've made a VI that uses shift register to pass the values of frequency of a sine wave and increment it by five during the next iteration. I'm wondering if the signal im producing is already a chirp signal or not?
What is the difference of my obtained signal from a chirp?
Please see attached file.
(3,834 Views)
Hi gijude,
why don't you stick with your older threads? You have been asking about Chirp signals (and related things) several times before…
I guess I already gave you a link to Wikipedia…
(3,826 Views)
Sir GerdW,
This is a different case, can you please help me with this VI. I just need opinions
(3,812 Views)
Hi gijude,
The difference is your formula to generate the signal…
Please read Wikipedia and use the formula given (and explained) there!
(3,807 Views)
