Chirp Signal Processing
I'm trying to process a Chirp signal to resemble the image named "desired signal".
A Blackman-Harris window and FFT provides the correct shape i'm after, but I need just the magnitude of this signal.
I then tried a spectrum FFT (magnitude peak) with a blackman-harris window. Which provided me with the magnitude response I was after, but the signal is ramping up between 4-12kHz, when I need it to ramp down.
Does anyone have any suggestions?
I've also attached my VI.
Thanks 🙂
(3,153 Views)
Hi mcollins27,
 As you mentioned above,can you please provide the details including amplitude, f1 and f2 ?
Srikrishna
(3,109 Views)
Amplitude = 10
F1 = 4kHz
F2 = 12kHz
Thank you!
(3,104 Views)
Hi mcollins27,
Context help says that the frequency ramping depends on sampling rate as well.
Can you please confirm what is sampling rate and other details?
Srikrishna
(3,086 Views)
I attached the VI in the first message.
The details such as sampling rate, amplitude etc. can be seen there.
Thank you
(3,061 Views)
