Choose which FPGA Program to load to Target
When loading the FPGA target with a VI, I'd like to choose programatically which VI to load.
Can anyone show the way ?  See attached .jpg.
(3,934 Views)
You could use a case structure...
Message Edited by SarahB on 08-30-2006 05:39 AM
Sarah
Applications Engineer | National Instruments | UK & Ireland
(3,925 Views)
Look at the Using the Upcast Function shipping example.  You can use multiple Open FPGA References as long as the front panels of the FPGA VIs are the same and you are not using DMA.
Joseph D.
(3,911 Views)
many thanks, upcast does exactly what I was looking for.
(3,869 Views)
