Chromatography
I research how to detect the start and the stop of a peak.I can just detect the peack and the valley for the moment. Thank you very much if you could help me (I'm french)... Merci
(3,185 Views)
In order to detect the start and the stop of a peak, begin at the peak location and move forward (or backwards) until the value drops below a threshold. The value at that location is the peak stop (or start). If the data is noisy (not monotonic on the sides of the peak) you will probably need to employ a more elaborate approach that uses a data smoothing technique (a five point cubic fit, is a personal favorite).
(3,185 Views)
