Circle Plot
Gentlemen,
As always, I get so far and then the 'wires' blow up...I put the vi to create the circle into my vi and put a separate xy graph to indicate it works!  There are also live orbit plots in the same 'loop'.  I can't figure out how to add the static circle plot to the orbit plot.
Ron Brook
Message 11 of 17
(2,386 Views)
Hi Ron,
which of all those unlabeled terminals are you talking about?
Message 12 of 17
(2,374 Views)
The front panel shows the two orbit plots.  Below them is your circle plot.  When I try to bundle your output to the array builder for the orbit plots, it doesn’t connect.
Message 13 of 17
(2,369 Views)
Hi Ron,
as your images miss all control/indicator labels and you aren't able to attach real code I cannot help much!
Especially as I don't even see where you try to "connect" (or bundle) any of those plots in this image…
Please do:
  1. Label all controls & indicators.
  2. Cleanup the VI.
  3. Attach the VI (or even better the full project)…
Message 14 of 17
(2,369 Views)
OK, back from the doctors.  Here is my issue in a nut shell.  The orbit plot is 'live'.  I have added your code to draw a circle on an XY graph.  Any way I try to add this to the orbit graph ends up with blown up wires.  Can you help?
Message 15 of 17
(2,352 Views)
Happens every time.  I started fooling around with the 'shortened' vi I sent you and I got it to work!  I used the Express XY vi and built the array of the two.  Works Great!  Thanks for the prodding.
Message 16 of 17
(2,351 Views)
Few comments:
  • Never ever maximize the front panel and diagram to the screen.
  • Never ever hide labels on the diagram.
  • If you confige the "From DDT" correctly, you'll get a 1D array, no indexing needed.
  • Your xy graph express VI just acts as a glorified bundle operation. There are better ways!
  • As we already said, it could be done with complex datatypes, greatly simplifying everything.
  • You don't need to calculate the circle millions of times.
Here is a quick refactor. Please check the rotation direction to make sure it agrees. (not fully tested).
Message 17 of 17
(2,347 Views)
