Citadel database
I have 2 question about this database:
1. Can I open this database with DSC(NI DB Tools Open connection) ? Or I must alwasy use "Open trace"?
2.How can I "manage" citadel database with SQL query? can be this done trough "NI DB Tools Execute" and SQL query?
What I wan to do is to read just some values from database and than with SQL query, calcculate omme values...
thanks
_________________________
Rookie; LV 2011 on WIN 7
(2,759 Views)
It should be possible through ODBC driver. DSC Run-Time should be installed, then you can use DB Tools from Database Toolkit.
Retrieving Data from a Citadel Database... [link removed; article no longer available]
Andrey.
(2,743 Views)
