Citadel databases
I am having problems with a DSC application, where for no reason the system is running fine and then about 2 or 3 days later the system just stops collecting data on both the Alarms and Events as well as the data from the field point gear. I have a background service that I developed that creates a report of the data present at the Fieldpoint gear every 1 minute. This application is working fine, but the historical collection of data (performed by DSC) on the system halts. Anyone have any idea about this phenom??? Also, I am having issues when I try to access that information via the MAX HTV, where for no apparent reason when I launch the viewer, sometimes the tags file appears and sometimes it does not? Any feedback is welcome.
(3,380 Views)
Hi Nuc appman,
Logging data in DSC is done by logos. There are a number of fixes to logos in the newer version. Upgrade logos to the latest version. Follow this link to the logos update:
http://digital.ni.com/softlib.nsf/954feaeea92d90918625674b00658b83/04b76c440048592886256d75006e6b8a?OpenDocument
Chad Evans
(3,380 Views)
Found the error though. Someone inadvertantly changed all of the Log Data %'s to 0 for 100+ points. This will cause a massive database to be created, not to mention some really out of control behaviors in the app.
(3,380 Views)
