ClA exam
I did my CLA exam 3 months ago and it was unsuccessful.
The main reason is it was an in class exam.
We only had a small laptop to do a multitasking exam that requires at least 2 extending screens. One for reading the exam paper and another one for coding.
The exam paper wasn't handed in, and everything had to be done in one small laptop screen.
The question is: is there any chance to do the exam remotely from home as it used to be?
The only reason I chose the in class exam is. I thought the exam paper is handed in.
(468 Views)
I'm guessing the remote test will be worse. You'll only be able to log into a remote session, use one screen, it will be visible to the proctor, and you will need your camera turned on and can't look like you're talking. You'll also be required to give a 360 of the room you are being tested in with the camera so they can see that you don't have notes posted on the wall.
Bill
CLD
(Mid-Level minion.)
(442 Views)
You are the first person I've heard who prefers the online exam. Usually I just hear horror stories...
Sam Taggart
CLA, CPI, CTD, LabVIEW Champion
DQMH Trusted Advisor
Read about my thoughts on Software Development at sasworkshops.com/blog
GCentral
(403 Views)
Definitely heard bad stories. Proctors simply not showing up for the agreed exam or not really having any clue about what they were supposed to do. Internet connection problems that either prevented logging in initially and when it finally succeeded it was declared to be to late and impossible to start or connections that broke halfway and resulted in an automatic disqualification.
Your in person test doesn't seem like the ideal experience either, but online for sure won't be better. Not sure why they could not provide a printed version of the exam paper, that seems like an easy thing to do if their systems don't have dual monitors. I definitely prefer the paper version, just feels easier to navigate.
Rolf Kalbermatter  My Blog
(354 Views)
I'm pretty sure the limiting factor was NOT the test environment. But there's no shame in failing. Now that you know what the test is really like, you can prepare for it more precisely.
Bill
CLD
(Mid-Level minion.)
(336 Views)
A valid comment. I did pass that exam in a long ago past where the exam was still always handed out in paper form. But it was not with what we call flying banners. Not because I couldn't do it, but I have never been the fastest programmer, LabVIEW or otherwise, around the block.
Looking at a video where Darren used to beat every person in the room single handedly in speed programming, always left me in a mixture of awe and head shaking. For me the 4 hours time limit was the real problem and no matter how much I would have trained, I knew this was going to be my Achilles heel.
(292 Views)
