Clad Doubts
Hii friends,
I am having lot of doubts in Clad online Questions....Here i have attached 2 doc files with questions...In that some of the Questions have been marked ...
can any 1 suggest me the answer for that questions particullarly DAQ related Questions.......
Message 1 of 8
(4,191 Views)
In the March 6, version.  #17 should be C.
#32 is a common sense question.  Do you think documentation is important?
#33 is D, you don't see any mention of base i/o address when you set up tasks in MAX.
In March 9, #10 is A.  All other functions on the palettes are also subVI's.  And you can also drag an icon from another open VI.  Actually rarely do you need to "Select a VI"
#20, I would suggest you open LabVIEW and try it out to get the answer.
#40 is C
Message 2 of 8
(4,185 Views)
another thread with same topic
Please stick to a single post for same kind of question
Message 3 of 8
(4,164 Views)
Here i attach 1 more doc in that can u suggest me the answers
Message 4 of 8
(4,141 Views)
Which of the following describes a Tab Control?
a. A control that outputs ASCII values equal to the selected tab label
b. A type of enumerated control
c. A control that outputs a cluster of the controls / indicators on the tabs
d. A controls that outputs the tab order of the controls on the front panel
Message 5 of 8
(4,140 Views)
Plz mention the answers for Daq related questions and other also
Message 6 of 8
(4,130 Views)
Are you actually trying to answer any of these questions?
The question about documenting subVI's.  You asked it originally and I gave you a clue.  Now these last two posts have the same question in it, and you still haven't answered it.
If you have a question or two that you really do have doubts about, then ask them.  Don't throw out numerous questions, many times repeatedly, just to ask us to grade your test for you.
Message 7 of 8
(4,113 Views)
b
- Partha ( CLD until Oct 2027 🙂 )
Message 8 of 8
(4,109 Views)
