Class VIs for access to private Data: reentrant or not?
I just created in a class some VIs for access to private data (my German translation). I'm talking about these VIs, which enable you to connect your class object to a property node to read or write private class data. These VIs are by default non-reentrant. My question is: what happens, if I try to access two objects of the same class with these property nodes? Does the second object have to wait for the first one to be read? If yes, can I circumvent this by making these VIs reentrant?
Marc
CLD
(3,031 Views)
Accepted by topic author Marc Blumentritt
In theory yes. In pratice it will depend on what you are doing in the private method and the methods it calls.
Ben
(3,023 Views)
OK, thanks for your reply.
Since the method are simple read / write actions and nothing more, making the VIs reentrant should be enough.
Marc
CLD
(3,012 Views)
