Class not registered
I am using Automation refnum in FP, and selecting Active X object, "MSCommLib.IMSComm" and when i open the block diagram and run the code, I get the
error whose image is attached.
Pls let me know what all may b the possible reasons.
(3,508 Views)
(3,490 Views)
IS there any way to avoid this error and load the active X , what are the necsessary things required to load that active X?
(3,480 Views)
HI
If you are using the Activex, make sure that control has registered properly.
Activex control can be register by giving the command "regsrv32 <activex control path>" on command prompt.
and also make sure you are selecting the correct component in activex cotrol.
Regards
Santosh
(3,475 Views)
