ClassID Array with integer
How I can't find classID of contents?
I need to know if it is array of string or integer!!
Thank
Emmanuel
(4,119 Views)
Accepted by topic author Clecle
If you create a property node for the array, when you select properties it allows you (for arrays) to select array element, and under that selection a selection for ClassID. The output of that indicates the class of the array element. A list of cooresponding numbers is at ClassID
Putnam
Certified LabVIEW Developer
Senior Test Engineer North Shore Technology, Inc.
Currently using LV 2012-LabVIEW 2018, RT8.5
LabVIEW Champion
(4,113 Views)
Hi Emmanuel,
                       Do you see this and this
Thanks as kudos only:)
(4,112 Views)
The ClassID doesn't tell you what type of numeric, just whether it is a numeric, string, varient, etc.
Putnam
LabVIEW Champion
(4,104 Views)
Thank LV_Pro,
I have make a mistake, my property node was generic when i take Tabl(strict), I found " ÉltTabl.IdClasse"
this is perfect
Thank
(4,098 Views)
