Clean Re-install Without Re-loading Windows XP Pro (aka Can I delete all National Instruments registry entries after uninstalling all NI products?)
Hello folks,
Something has gone terribly wrong with one of my testers, and I think it calls for a clean installation of all NI products (i.e. PXI/SCXI chassis, NI controller, FPGA, LabVIEW, traditional DAQ, DAQmx etc.).  However, I don't want to re-load windows.
Can I safely delete all of the National Instruments registry entries after I uninstall all NI products?  Will this provide a "clean slate" for me to re-install the NI products?
Best Regards,
Chris
(3,645 Views)
Chris,
I suggest that you try MSI Blast to remove the previous install.  You can find it and the instructions from NI here .
(3,628 Views)
Hi Wayne.C,
Thanks for pointing me to MSI Blast.  Although it did not work in this case, I can certainly imagine it being a useful tool in the future.
After all was said and done I ended up reformatting and spending tens of hours of searching for and reinstalling software.
Best Regards,
Chris
(3,584 Views)
