Cleanest way to add a second to date/time?
I have a bunch of singles with the date and time in them from year down to tenths of milliseconds.  I want to add 1 second and have the rest update.  This is the cleanest way I've come up with.  I'm not too fond of the bundling and unbundling but I can't think of another way.  Anyone have an easier/faster/cleaner way?
Lee Jay
Message 1 of 17
(4,216 Views)
Hi Lee Jay,
do you have to use this format (splitted into several data types)?
Because the time stamp format is easier to handle (and you could easily add 1 second). With the formatting variaty you can almost do everything with timestamps.
Ton
My LabVIEW Ideas
Message 2 of 17
(4,206 Views)
Yes, I must use the split-out format.
Lee Jay
Message 3 of 17
(4,196 Views)
Lee Jay,
If the original value of Seconds = 59, does your code do what you want? You may need to propagate overflow throughout the cluster.
Lynn
Message 4 of 17
(4,193 Views)
Yes, the whole point of doing this is to get minutes, hours etc. to roll over properly.  And this code does work for that.
Lee Jay
Message 5 of 17
(4,185 Views)
By the way, adding 1 after the conversion works the same.
Lee Jay
Message 6 of 17
(4,180 Views)
Maybe I'm missing something, but isn't just adding 1 second like in the attached example what you want to do?
Message 7 of 17
(4,168 Views)
That's exactly what I'm doing, but I have to start and end with each component of time/date in individual singles.
Lee Jay
Message 8 of 17
(4,156 Views)
Lee_Jay,
I think all that you really need to do is add 1 to your timestamp.  I've attached a quick example.
Hope this helps,
Dan
Message 9 of 17
(4,159 Views)
I don't have a time stamp.  I have 7 singles and I need to end up with 7 singles.  That's the problem.
Lee Jay
Message 10 of 17
(4,147 Views)
