Cleanup on Producer/Consumer template puts consumer above producer?
See the attached pic.  I have the stock "pro/con" template, and the i do the auto block diagram cleanup and then it spatially positions the consumer loop on top of the producer loop.  Is my block diagram cleaner upper behaving correctly?  Is there a way to force them to stay in the stock orientation with the pro loop above the con loop?
Thanks.
(2,679 Views)
It probably did that because the one with the producer on top has the queue wire crossing the error wire.  Consumer on top, that doesn't happen.
Pick each loop individually and conduct block diagram cleanup on each.
(2,664 Views)
It's avoiding the wire crossing over the error wire with the queue reference.  Personally, I prefer having the Producer on top; data flows down.
So to answer your question, there is nothing wrong with your Diagram Cleanup.
(2,661 Views)
