Clear Output when not running
I am running LabView 8.6 with USB-6525 modules. Is there a way to automatically "Clear" or set the Outputs to False when the VI is Stopped? I know I could set them all to false after the Stop button from my while loop is pressed but it would be nice to automatically do this.
Thank You,
Jason
Message 1 of 8
(3,808 Views)
Accepted by topic author JTMX39
No.  You will have to set them to false before your VI actually ends.
Message 2 of 8
(3,805 Views)
OK, Thanks!
Message 3 of 8
(3,801 Views)
On a related note, you can set the startup state of the lines in Measurement & Automation Explorer by right clicking on the device and going to Properties.
Jeff | LabVIEW Software Engineer
Message 4 of 8
(3,767 Views)
Hi Jeff -
When I right click on the USB-6525 in MAX the PROPERTIES is greyed out so I can't select anything.
Message 5 of 8
(3,746 Views)
Are you running your application or test panel at the time? What version of the DAQmx driver are you using?
Message 6 of 8
(3,716 Views)
No, I am not running anything else. I even rebooted the computer and went right to MAX.
LabView v.8.6
MAX v.4.5
NI-DAQmx v.8.8
Message 7 of 8
(3,706 Views)
It turns out this is something that was added in DAQmx 8.9 (it points out in the README).
You can download the latest DAQmx driver here.
Message 8 of 8
(3,681 Views)
