Clear array and take average of values in array continuously
I have a continuous signal that I am acquiring with hardware (sampling at 1000Hz).  I want to be able to insert the data into a 1D array for 5 seconds, and then take the average of these 5000 samples.  So basically, every 5 seconds I need to take the average of a 1D array and create a new array for the next 5000 samples.
(2,559 Views)
There is no reason to accumulate the data into an array if all you need is the average.
Simply add the values into a shift register. Every 5000 points devide the sum by 5000, output the average, and zero the shift register for the next series of data..
(2,544 Views)
