Clear errors and switch to operational mode in EtherCAT Industrial Communications
Hi all,
I am using an NI 9045 CompactRio to communicate with a motor drive via EtherCAT.
Is there a way (not using SoftMotion) to clear device errors (if there are any) and then switch to operational mode programatically?
I am currently doing that using the Online Slave Device State window (see image). Are there any VIs or such that I can use to perform this task?
Omar
(3,714 Views)
Hey O.Alahmad,
There are Clear Errors.vi you can use to clean the device errors in your code. However, NI-EtherCAT doesn't support switching to operational mode programmatically.
(3,687 Views)
Accepted by topic author O.Alahmad
Hey O.Alahmad,
NI provides Invoke Node which can apply to switch the slave mode in the program.
(3,673 Views)
Hi zhengchen,
Yes! That did the trick. It completely passed my mind that I can use an invoke node. Thanks!
Omar
(3,664 Views)
