Clear graph.
I'm using a local variable of an xy graph to clear it but the result is that only clears the graph while the button clear is clicked. After this, last plot apears again. How to solve this.
(3,502 Views)
Your mistake is that you clear local variable but you dont clear shift registers that you are using for cluster bundling. Instead clearing local variable clear shift registers.
Good luck.
(3,502 Views)
Thank you Navav.
But unfortunately I don't know how to clear shift register also.
Rehards,
Soto
(3,502 Views)
OK, here your vi with changes.
(3,502 Views)
Many, many thanks.
It works and I learn how what is most important.
Best wishes.
(3,502 Views)
