Clear txt file
Hi All !
I write some data to a file, but before i do it i want to clear the file from previous content.
Surprisingly i didn't find any control/function to do the operation.
I'm using LV 7.1.
(3,209 Views)
Accepted by topic author john7
Hi John,
ever tried to "create or replace" a file instead of "open or create"?
There also exists a "Delete File" function, in case you don't trust the file open function and their options...
(3,197 Views)
Since you have the Path to the file you want to replace in the 'WRITE' case you coud use the 'Delete.vi. in 'Advance File Functions' Bottom right in the FILE I/O section of the Programming pallette.
(3,191 Views)
Create or replace option pops-up a dialog. Delete is an option, also in C/C#  it's quite a simple operation to clear a file.
(3,187 Views)
It's OK! There is a flag to suppress pop-up dialog. Thanks a lot!
(3,184 Views)
Hi John,
"Delete is an option, also in C/C#  it's quite a simple operation to clear a file."
Either use the Delete function or try the SetFileSize/SetFilePosition functions...
How would you do that in C/C++/C# anyway?
(3,181 Views)
"How would you do that in C/C++/C# anyway?"
It's library functions but I think on a low level it goes like this (it's pseudo code):
while(!EOF)
   clear(or replase) char at position;
    increment position;
(3,177 Views)
