Clearing Event Sequence Triggers / Queue
Hi
I used a "mouse down" as under "value change" the false > true action is a trigger and the return True > false is a stored trigger for the event structure and triggers straight away again on the next loop of the software. I was therefore ONLY looking for the downward press but as you can see that didn't work to good either lol
Message 21 of 27
(1,599 Views)
@NToombes wrote:
Hi
This is only true for switching mechanical actions. If you use Latch when Pressed or Latch when Released mechanical action this will not be an issue.
Message 22 of 27
(1,586 Views)
@NToombes wrote:
Hi
Do you have your buttons set to "Latch Until Released" something?  Otherwise, where does this "return True > false" event come from?  That doesn't happen with standard buttons.
Message 23 of 27
(1,574 Views)
Hi all
OK, I have thrown the towel in on this one for now and but the start button in a simple while loop that executes 20 times a second with a button press stopping the loop. Horrific I know but it works!
Seems to complex to just instigate some cod that awaits a button press before continuing. I tried some of the other options listed before this post and yes, they worked but then my other buttons stopped responding etc & the Start button seemed to hold in the "on" state, not what I wanted.
I need to spend some more time on these event structures, not as simple as they look on the surface.
Neil
Message 24 of 27
(1,553 Views)
You might want to show some code.  I suspect you have some significant design problems.  Your non-responding buttons sounds like you are trying to do UI work inside an Event Case that is locking the UI while it executes.   You can easily turn that lock off, but you'd be better off fixing your design issues.
Message 25 of 27
(1,545 Views)
I agree with this. It seems like you are way overcomplicating this.
Message 26 of 27
(1,530 Views)
From the description I see two simple solutions.
1. Disable the button as the event activates.
2. Use Lock event structure if it's happening during the button event
Both will prevent accidental presses.
A slightly more advanced solution is to register the button value changed as a dynamic event and (un)register as needed, but that seems overly complicated. 🙂
Qestit Systems
Certified-LabVIEW-Developer
Message 27 of 27
(1,527 Views)
