Clearing a Chart/Graph programatically
Is there a way to clear a graph or chart at the time the program
starts. I have looked at the attribute node values but there is
nothing I can see that would do this. The problem is when I restart
the program the charts x axis keeps growing and I want it to always
show the same starting point. Thanks for any help.
Steve Drake
(3,107 Views)
Under the help menu: Search examples. Select graphs and charts. There is
a vi called How to clear charts and graphs.
Steve Drake wrote:
> Hello,
> Regards,
> Steve Drake
(3,107 Views)
Under the examples for graphs and charts, is an example dealing with
clearing graphs through programming (sorry the information is at home).
Basically, I guess, you have to wire an empty array to the graph when the
program starts.
Good Luck,
Christopher Quijano
Steve Drake wrote in message
news:fmnoas0fe9du8chlbkp6l8i2qs954mdql7@4ax.com...
> Hello,
> Regards,
> Steve Drake
(3,107 Views)
