Clearing of Feedback Node
Greetings,
Is it possible for the Feedback Node to be cleared from our VI?
So that the feedback node will not use the previous value for the next execution.
My project is dealing with optics and motorized stages.
After running it once, for about 1 degree, when we change the movement to 5 degrees,
the programme will run 1 degree, then 5 degrees.
Apparently, this is not what we desired.
So please do assist me.
Your help is much appreciated.
(2,429 Views)
Could you post the ocde you've already done?
Do you know which behavior you expected?
The behavior you're explaining seems to rely on commands you've done. Where is the problem?
Olivier L. | Certified LabVIEW Developer
(2,427 Views)
