Click on table scrollbar
Hi
i've a problem
i have an event structure with a table
when i click into a cell a dialog box ask me some values and it works properly.
When i've several values into table 2 scrollbars are visible and the click on the scrollbars arrows (and on bars) are treated as event and the dialog box appears again.
How can i separate this two "clicks behaviour" ?
thanks
http://www.sd-studio.it - web design agency
Message 1 of 15
(6,424 Views)
could you post an example?
I am not sure you need an event with a message box to insert values in a Table cell.
AlessioD
Message 2 of 15
(6,410 Views)
no...the problem isn't how to insert values etc...this works great
the problem is understanding the reason why when i click on the scrollbar to move left or right the event structure execute the code inside the "mouse up" event.
Message 3 of 15
(6,407 Views)
when you click you are generating Mouse Down and Mouse Up in sequence. You can see this if you click and hold down the mouse button, the Mouse Up event should not fire.
AlessioD
Message 4 of 15
(6,403 Views)
hi
but the problem isn't the click and the event
i can't understand why the click on the table scrollbar produce an event.....
only this....
Message 5 of 15
(6,401 Views)
well, the scrollbar is part of the table. If you have added an event case that handles Mouse events on the Table Control, then whenever you click on part of the table (i.e. scrollbar), the event is fired.
AlessiOD
Message 6 of 15
(6,399 Views)
and how can i handle this 2 different beahviours?
cells instead of scrollbars?
thanks
Message 7 of 15
(6,396 Views)
here we are back to my first question.
Why do you need to handle Mouse clicks when inserting data in a table cell?
Table Cells are editable at runtime just by clicking on them and directly typing the piece of data you want to insert. Is there any specific reason you want to use events to insert data?
Message 8 of 15
(6,390 Views)
because each cell is a complex structure of data for me so each cell contains several values
Message 9 of 15
(6,387 Views)
ok,
post an example so that we can see what can be done here
Message 10 of 15
(6,385 Views)
