Clickable Link to a Web Site
Is there a way to add a link to a LabVIEW Front Panel so when you run the VI and click on the link, it will open a specified URL using the default browser?
Thanks!
(7,434 Views)
C:\Program Files\National Instruments\LabVIEW 2010\vi.lib\Platform\browser.llb\Open URL in Default Browser (path).vi
Not sure where it is in the palettes - I just snarfed the above path from my code.
Steve Bird
Culverson.com
LinkedIn
(7,429 Views)
To be more specific, you can have a disabled string control on the FP with the URL and then use a mouse down event on that string to call the VI.
___________________
Try to take over the world!
(7,421 Views)
This idea never gained much traction.
(7,412 Views)
Sounds like an ideal opportunity for a little XControl.
This would hide all the fluff required to make it highlight on mouse over and open a web-browsed on selection.
Thoric (CLA, CLED, CTD and LabVIEW Champion)
(7,409 Views)
(7,401 Views)
Thank you - this is the best example yet. I've added the code that Steve Bird suggested above and here is the VI based on your example attached.
Thank you all!
(7,396 Views)
