Client does not have access to specified VI
I use web server to remote access vi running on the server computer (myrp.vi in myproject.lvproj). When I set the visible vi as "*", there's no problem. But once I set it to "myproject.lvproj/My Computer/myrp.vi", I get the message "Client does not have access to specified VI".
Also, when I try to add visible vi programmatically as the attached pic show, it did nothing. If I changed the string to "+myrp.vi", it worked fine but still get the same message.
Can any1 help to figure it out? Thanks.
p.s. I'm using labview 2011 pro
(3,855 Views)
Anybody has any idea?
(3,828 Views)
Hey Eric LZ,
Have you tried adding the VI to the permissions list without the directory path for example test.vi.  I supsect this is causing your issue.  I would also make sure that the server is enabled both with the client and the server.
Kevin Fort
Principal Software Engineer
NI
(3,793 Views)
Actually, I tried use "myrp.vi" directly without directory first. it did not wor, then I searched online and found the following document,
https://www.ni.com/docs/en-US/bundle/labview/page/adding-new-visible-vis-entries.html
but still didn't work.
now I'm using "*myrp.vi" as temp solusion.
Thanks.
(3,780 Views)
Hey Eric,
So even when you structure the path like this: MyProject.lvproj/My Computer/MyVI.vi you get the vi cannot be found error but when you just use a wild card before the name it works fine?
Kevin Fort
NI
(3,774 Views)
yes, for a VI resides in a project, neither "MyVI.vi" or "MyProject.lvproj/My Computer/MyVI.vi" did not work, but "*MyVI.vi" worked fine.
(3,772 Views)
