Clipped sinusoidal waveform
I have a sinusoidal waveform and when I increase the above 10V peak-to-peak my waveform is clipped. I have used both USB-6211 and USB-6351. I know the that pins have an input range ±10V. Is there any way I can fix this?
Kind regards,
Michail
(3,438 Views)
Accepted by topic author MichailM
Are you sure you set the input range correctly? (There is also a ±5V setting among others). Can you show us a simplified version of your code?
(3,428 Views)
In the "DAQmx Create Channel" I did not set the minimum and maximum values. Now it is ok.
(3,383 Views)
