Clone a controller with Hypervisor Installed
All,
Is it possible (i.e... safe) to clone a controller? In this case it's a NI PXIe-8133.
Carmine
(4,020 Views)
Yes it is possible and I have in fact done so but.  1 word of caution.  Licenses!  make sure you fix any software licenses.
(4,018 Views)
To add on to the previous comment, yes it is possible to clone a Hypervisor controller. We have some guidelines published on the topic in the following white paper: Best Practice for Backing Up, Restoring, and Replicating NI Real-Time Hypervisor Systems [link removed; page no longer available]. Please do note the comment on licensing as well -- for a typical Windows Hypervisor controller, this typically means having at least the following licenses for the clone: Windows OS license, LabVIEW Real-Time Deployment License, and an NI Real-Time Hypervisor Deployment License.
Sanjay C.
Embedded Software Product Manager| National Instruments
(4,011 Views)
Why is licensing such a problem? Could they not be added later?
thanks
(3,997 Views)
Accepted by topic author CarmineS
It is not a problem. It is a leagle requirement. It can become a problem when the end user says "OK this system works-I do not need to do all that booring stuff like appling licenses"
guess who is also going to court when the license violations are noticed? yup the person who installed the illegal copies.
(3,992 Views)
As I read the tutorial for backing up the system it made sense about the license.
Let me restate (clarify) the issue:
I want to clone the controller so that I can restore the same system back to the same controller in the event of a problem. It was not intended to build extra systems on other controllers.
Thanks for the help
(3,979 Views)
If the purpose is to create a backup so that you can restore back to the same controller, you don't need to worry about the licensing as you should already have it all in place. You'll need to watch out for documenting licensing if you are going to be replicating systems.
Sanjay C.
(3,973 Views)
