Close COM-Port
Hi
When I use COM-Ports in my VI, they're open still I close LabVIEW. Is someone
there who has a solution for this problem?
I'm searching for a VI, that closes my I/O-COM-Port.
Chris
(5,573 Views)
There is a utility serial vi called 'Close Serial Driver' that will close
the serial port. It is located in the LabVIEW directory in vi.lib/instr/_sersup.llb.
Call this before your program exits.
"Chris Herzig" wrote:
>>Hi>>When I use COM-Ports in my VI, they're open still I close LabVIEW.
Is someone>there who has a solution for this problem?>I'm searching for a
VI, that closes my I/O-COM-Port.>>Thanks >>Chris
(5,573 Views)
hallo chris.
hi chris.
i know this problem and it's quite easy to solve:
..\labview\vi.lib\instr\_sersup.llb\"close serial driver.vi" is exactly the
vi you need. you van find some other useful vis at this location.
(5,573 Views)
