Close Excel File after getting data from it
Any switch action that's configured as "Latching" will latch - simply a quick "on-off", and the value will not change once, but will go high then low again.
"Switching" is what you're talking about.  When you use switching, it's more like a light switch.  The new value will hold until it is once again changed.
If you righ click on your control->properties->mechanical action, if gives a good explanation.
Message 11 of 12
(733 Views)
Ok, thanks. I understand. I tought it had something to do with the Event Structure. But no, its just a button property 🙂
I think it's all. I learned a lot with your help.
Message 12 of 12
(729 Views)
