Close FPGA VI Reference breaks when moving project...
I created a cRIO project with an FPGA target, and assigned the output of Open FPGA Reference to an indicator.
When I moved the project to a different computer, the wire to the indicator broke, so I selected "Bind to Typedef..." on the Open FPGA Reference node, replaced the indicator, reconnected all the local variables from old indicator to the new one, and deleted the old one. So far so good.
But now, when I move the project to a different computer, the wire to the Close FPGA VI Reference breaks.
If I delete and replace the broken wire whenever I open the project on the new computer, everything's fine. Am I stuck with that? It could be worse, I guess, but I'd like to fix this for real. Any suggestions?
Thanks in advance.
(3,606 Views)
Hi Ron,
I do not believe that there are any other workarounds for this behavior.  I've been attempting to fix this myself in another way, but it seems that due to the simplistic nature of the close reference vi, it is not possible to go about this in another way when distributing applications.  I will try to see if we can make a product suggestion for this in the future releases of the software.
(3,249 Views)
