Close Front Panel Causes System Hang.
I have an application where there are several front panels that I would like to have open at once, but where when they stop they would close.  I was using the scripting function fp.close - but as the application has got more complicated this seems to work less and less well.  Basically when i hit close, the system hangs for a few seconds, then the time critical stuff i have tends to timeout and then crash, and everything goes funny for a while.
My (uneducated) guess is that when it closes a front panel it drops loads of stuff straight out of memory - in an uncontrolled way.
After going for a cup of coffee it usually sorts itself out.  But clearly this isn't a sustainable solution for my application or my kidneys.
Am I doing something wrong? - Is there something i should do to allow the Vi to finish before i try to close it? Should i be releasing references or somethign to make things better.  I thought about running the close vi sub as a new thread - but not sure if this would actually do anything different.
Attached - the subroutine that i pass a vi ref to.
(3,015 Views)
There's nothing in the attached VI that would necessarily cause your problem. I would, however, suggest that you feed your reference through the nodes in proper flow control method rather than branching off like you've done.
When a VI fails to close quickly, I have most often found it's due to open references which aren't explicitly closed. File references, VI references, multiple calls in a loop acquiring the same reference over and over without releasing it, .NET calls not being closed - that kind of thing.
Richard
(3,007 Views)
Hmmm.
That might make some sense.  I have a feeling i may have some queue references left over somewhere.  Also some of my measurement data objects.  One quick question - with data objects without 'references' to active objects - ie with just arrays of values is it necessary to create a destroy method for each one - I was doing this at one point but I thought I had read somewhere that it wasn't necessary.
(2,990 Views)
Dynamics need closed statics do not. OYu can tell the difference (with time by just looking) but when learning you can use a type cast fucntion (see data minupulation palette) and cast the ref as a U32 and an indicator for same. It the U32 values changes when you run the VI, it is dynamic.
Ben
(2,988 Views)
