Close TS Sequence in Labview
I need help in doing the following from Labview.
I have a sequence file that contains some sequences. I want to be able to search for a sequence inside the sequence file, clone it under the same parent sequence, rename it, then apply some values to its global variables. So far, I figured out how to get the the sequence inside the sequence file, but I couldn't find a way to create an exact copy of it in the same parent.
Any help on this is appreciated.
Sam
(2,779 Views)
Sam,
this is better placed in the TestStand forums....
You have to clone the sequence. Clone is a function of the PropertyObject class, so you have to cast the Sequence into PropertyObject.
hope this helps,
Norbert
Norbert
Expert: Geometry
(2,776 Views)
