Close execution of .exe started with SystemExec
Hello. I used the SystemExec function to launch a .bat file that opens an application (MyProgram.exe file). Then I see that the application run in the black window (like the command prompt window). In the upper part of the window it's called as "C:\WINDOWS\system32\cmd.exe".
I need to close the execution of MyProgram.exe after a fixed time. I tried some test with the SystemExec function but I haven't found a solution.
Inside the .bat file there is only this line:
@MyProgram.exe -v
Message 1 of 17
(499 Views)
Use the taskkill program. Launch another cmd with this command line:
cmd /c taskkill /IM MyProgram.exe
Of course, this will abruptly terminate MyProgram.
Generally speaking, the best way would be to be able to send a "message" (e.g. using UDP) to MyProgram.exe that would terminate itself.
Paolo
LV 7.1, 2011, 2017, 2019, 2021
Message 2 of 17
(480 Views)
I tried but it opens for an instant a new black window and then close it, but the original one with the execution of the program remains open.
Message 3 of 17
(450 Views)
What is the output of taskkill? I tried it and it works with notepad.exe
Message 4 of 17
(443 Views)
Try
taskkill /IM etc.
in a standard command prompt window and see what happens
Paolo
Message 5 of 17
(427 Views)
I used the SystemExec block with this command line:
cmd /c /taskkill /IM MyProgram.exe
The value of return code of the SystemExec block is 1, standard error is "Not found".
Message 6 of 17
(402 Views)
Message 7 of 17
(395 Views)
First, you should remove the forward slash / before taskkill:
Second, you can add the /F switch to forcefully end the process:
cmd /c taskkill /F /IM MyProgram.exe
Refer to the taskkill documentation.
Also, keep in mind that if the process you want to kill is running with higher privileges, you cannot terminate it with taskkill from a program with lower privileges — this is obvious and expected behavior.
Message 8 of 17
(368 Views)
This VI is missing "PostMessage Master.vi".
Message 9 of 17
(355 Views)
Out of Labview I managed to open and close the prompt window using PowerShell. Can I use the SystemExec block to launch it and execute the same commands that I tried out of Labview? Thanks.
Message 10 of 17
(334 Views)
