Closing VI from its Sub VI
I'm opening this vi from a larger one, and it triggers a pop-up subvi once the volume is reached, but I cannot figure out how to make the subvi close itself and this vi at the same time.
So process is like main vi (that i havent sent here) -> push water vi  starts-> the right number is reached - > pop up subvi going are you done? -> close both subvi and push water - > go back to main vi.
How do I make that happen?
(567 Views)
Why do they have to close at the same time?  Isn't it enough to close the subVI and then close the top level after?
Bill
CLD
(Mid-Level minion.)
(545 Views)
Replace that silly Event structure with a Case and place the FP.close in that. Also, remove that while loop.
Qestit Systems
Certified-LabVIEW-Developer
(511 Views)
