Closing a Program (explorer.exe)
Hi there ,
Does anyone know how do I close a program from LabView.
I need to close explorer.exe which is not called by Labview. I am using LabView7.0 Win XP.
Thank you in advance.
Deepu
(3,344 Views)
Have a look at this little utility:  http://www.nirsoft.net/utils/nircmd.html
I've not used it before.  But it looks like it might be perfect for what you need.
Good luck!
Patrick Allen: FunctionalityUnlimited.ca
(3,334 Views)
Thanks man,
Looks like it is going to work!
Thanks a lot...
(3,317 Views)
As another option, you can try looking for a library called LVWUtil32. It includes a VI called Quit Application, which sends a quit message to whatever window you choose.
___________________
Try to take over the world!
(3,312 Views)
Hi tst,
Thanks for the alternate solution.
That was even better. I can chose the window that I want to close.
Thanks!
Deepu
(3,295 Views)
