Cluster VI Reference Minor Bug
Over on LAVA PJM_labview posted a video of a bug found in LabVIEW 2013 SP1.  It is a minor bug with the block diagram when showing a cluster constant with a VI reference constant in it.  Here is the video of how to reproduce the bug.
http://screencast.com/t/gfKwlvMcCsHI
And here is the original thread on LAVA.
http://lavag.org/topic/18297-cool-little-lv-2013-sp1-bug/#entry109757
(3,555 Views)
I played with this and filed it as a CAR (#479432). Intriguingly, there are a couple workarounds:
Option 1
On block diagram:
1. Create cluster constant containing refnum with auto-sizing set as arranged (vertical or horizontal)
2. Create typedef
3. Unlink from type def
4. Change auto-sizing to desired value
5. Recreate typedef
Option 2
On front panel:
1. Create cluster containing refnum control
2. Create typedef
On block diagram:
3. Create constant from cluster typedef on block diagram.
4. Unlink constant from typedef, change auto-sizing as desired, recreate typedef
(3,497 Views)
