Cluster display question
Is there any way to place a control or indicator on a vi's panel, so that it is
within the frame of a cluster, but not a member of the cluster?
Randall Miller
(3,413 Views)
Yes, move it with the arrows over the cluster. You will see a shadow
indicating the overlap but it disappear when the VI runs.
Jean-Pierre Drolet
Scientech R&D inc
Trois-Rivieres-Ouest (Quebec)
CANADA G8Z 4H1
Randall Miller a écrit dans le message :
20000419222434.26268.00001348@ng-fa1.aol.com...
it is
> Randall Miller
(3,413 Views)
Select the control or indicator and then while it is active, use the arrow
keys to move it over the cluster. It will cast a shadow over the cluster
(make sure that the control or indicator is frontmost using the reorder ring
on the toolbar). This shadow can be made non-visible if the background of
the cluster is black. I think that that is the only solution.
-Jim
it is>within the frame of a cluster, but not a member of the cluster? >Randall
Miller
(3,413 Views)
Thank you for the help. Where ever that is stated in National's documentation,
I missed it.
Randall Miller
(3,413 Views)
