Cluster question
Please have a look at the vi. I have a cluster array with multiple elements. I also have a array of strings. How can I index this cluster with the array of strings? What I want is the sting of array will have lets say Loadprofile0, Loadprofile1, positionprofile0 etc..for each profiles, I want to select the corresponding cluster data. THanks
(3,758 Views)
There are two ways you  can do this. maintain a 1 to 1 correspondence with the string array and clustr or you can search the profile cluster with the name. Maintianing a 1 to 1 correspondence is the easiest but requires a bit more up front work.
(3,751 Views)
Another method is to use the OpenG Variant library. You can see an example of this here.
(3,735 Views)
Seems like it is a perfect solution for my problem. Problem is I cant get this Open G library. I went to the OpenG website but somehow I cant get the package. Can you pls upload the vis in here?
(3,701 Views)
What were you trying to get? The easiest way to install the OpenG libraries is with the VI Package Manager that they distribute.
(3,695 Views)
