Cluster to string
Hi
I'll send you the LLB including the VI's to decode LV5.1.1 structures (about
500kB zipped so not attached to the newsgroup). I hope all sub VI's are
included.
Two examples are included:
TEST2 will simply convert the variable to a string. Try to write something
in the 'section' variable and see the difference.
TEST3 will convert a variable to a string, write it to a configuration (ie
text) file and read it back to a new variable withe the same structrure and
name.
Have fun
Hans
Message 8 of 22
(2,844 Views)
Would you also forward me a copy of LV_STRUCTURE_DCODER.LLB. I am working with LV 6.1 so I am not sure how well it will work but it would definitely give me ideas to write my own routine.
Thanks in advance.
OS (oas@stress.com)
Message 12 of 22
(2,775 Views)
HI together,
could anybody send me the "LV_STRUCTURE_DCODER.LLB" to my mail (see attachment) or maybe in the meanwhile is there
any new solution for this problem?
Thanks Thomas.
Message 13 of 22
(2,426 Views)
Hi RB,
      See EXAMPLE in the attached LLB.  It's supposed to decompose arbitrarily complex Clusters into an INI-stye format text, however, it's much more readable if the cluster is composed of atomic-types (Numeric, String, Bool) because some "syntax" was needed to keep track of nesting.  It's a work in progress and by no means "road-tested" - but maybe you can change the output format to meet your needs.
Cheers!
Message Edited by Support on 01-24-2007 11:40 AM
"Inside every large program is a small program struggling to get out." (attributed to Tony Hoare)
Message 14 of 22
(2,422 Views)
that's nearly that what I searched. The only problem is, that I cannot connect to the example.vi as subVI
any kind of cluster. I tried it with variant conversion but then, the VI doesnt' work anymore.
Isn't there any simple trick to connect any kind of cluster to the example.vi?
Thanks, Thomas.
Message 15 of 22
(2,417 Views)
Hi Thomas,
      If you replace the Cluster in Example.VI with on of your own, it should work.  But, here's another LLB with a Wrapper which takes a Variant input - so you can wire anything to it! Smiley Happy
Please keep in mind that this code is very new and I expect will need some more work! Smiley Wink
Cheers.
Message Edited by Support on 01-24-2007 11:39 AM
Message 16 of 22
(2,408 Views)
** First Post Alert **
Hi to All!  I found this thread searching out how to write a cluster to a text file.  It turns out that this is easily done using an OpenG package. Check this link:  http://forums.ni.com/ni/board/message?board.id=170&message.id=218523&requireLogin=False     I know, I know you want to convert the cluster to a string. 🙂  Well, you could read the text file back in as a string.  Or you could take a look at the Source vi, "Write INI Cluster".
B_Yeske
P.S.  Thanks for VIPM, Jim Kring!
Message 17 of 22
(2,362 Views)
The OpenG subroutine is amazing, it saves *a lot* of time.
I attached an example (using LV8.2.1) for a little improvement (maybe it is already possible to do that).
PROBLEM:
If I have a menu ring in the cluster, the openG function write the number insted of the "string value".
I want to have the string value of the menu items
The result ini file of my example is this:
[Setup-1]
SCL=1.0
OS1=0.0
OS2=0.0
OAU=1.0
INP=1
T2=0
DS=0
but I want INP=ST1 and SCL=2°C. Is that possible? any idea using some openG power-tools?
Message 18 of 22
(2,244 Views)
A ring's value is only the number. The strings are only used for the display part, so once you put the ring into the cluster, you don't have any real way of extracting the strings.
The strings can be extracted from the control itself by creating a property node (right click on the control or the terminal and select Create>>Property Node) and selecting the Strings[] property, but you can't use that in the OpenG code, because it only accepts the numeric value of the ring.
If you want another option, the easiest option is probably to use a combo box (in the string palette) which is similar to the ring, but has a datatype of string.
___________________
Try to take over the world!
Message 19 of 22
(2,235 Views)
I have been struggling with this issue of cluster (or any control type) serialization.  In languages like java and .net complient languages the Object pase class has a method toString().  A to string function does exactly this.  It would be nice if in future versions a tostring, fromString is implemented right into the gObject so a general method of serialization is possible.  This function could handle all data types including arrays and clusters.  Flatten to string is close to this but it is not nice for init files and data saving.
Paul Falkenstein
Coleman Technologies Inc.
CLA, CPI, AIA-Vision
Labview 4.0- 2013, RT, Vision, FPGA
Message 20 of 22
(2,225 Views)
