Cluster visualization wrong???
I have the following problem.
I have a PC and a Laptop, both with the same Installation and Setup.
On the Laptop the visualization of a cluster differs to the PC. It is bigger and not everthing is visible (scroll bar for example).
Also the lines are not at the same level.
Has abnybody a idea why thats so?
Take a look at the pictures attached.
Thx.
(3,969 Views)
Hmm, a different screen resolution and font anti-aliasing/smoothing?! The difference is not LabVIEW origin, I guess.
Cheers,
(3,919 Views)
but the resolution of booth screens is the same.
(3,912 Views)
Dear stefkum,
it is hard to believe that the resolution of your laptop monitor is equal to that of the monitor of your destop PC, exactly. I believe you checked correctly, and you are the lucky one possesing such hardware combination (it is meant to be a kind admiration). By resolution I mean the number of vertical pixels times the number of horisontal pixels.
The ansicht_pc.png misses antialiasing of fonts, but that would not explain the scaling change.
The fonts in the two screenshots differ as well. Not only in the font-shape/family seems different, but their sizes, too. Check the fonts in the arrays on both systems, please.
Cheers,
(3,906 Views)
Accepted by topic author stefkum
The latter computer has Large font setting in display properties.
/Y
Qestit Systems
Certified-LabVIEW-Developer
(3,900 Views)
thanks, thats the solution!!
(3,892 Views)
