Clusters - naming
Hello everybody
How I can name the variables going into the new build cluster.
For instance I generate the product of two digits and then
together with others put it into cluster. Whow can I name this
product to be able to use the name later after unbundle the
cluster?
Many thanks for help.
PP
(2,859 Views)
You can use bundle by name, and in the middle cconnection use a cluster constant with the names (labels) you want. This way you can select each numbers name in the created cluster.
Hope this helps
(2,859 Views)
Thank you.
Best regards
PP
> Hope this helps
(2,859 Views)
Hi Pawel,
when you use the function Build Cluster you can input the type of cluster you want to build, i.e. re-name the cluster components.
I attach an example that does what you ask.
If you want to re-name the components just change the labels in the cluster constant.
Good luck,
Alberto
(2,859 Views)
