Code MAXStoppedServiceError
This is my problem:
Deploying Shared Variables.lvlib\\10.23.63.97\Shared Variables deployment failed (error: -2147220693, MAX:  (Hex 0x8004032B) The configuration database is not running. Restart your system and try again. Visit ni.com/info and enter the Info Code MAXStoppedServiceError if the problem persists.).
(4,858 Views)
Hi cRIO-9215,
You try do the corrections suggested by the document on ni.com/info
http://digital.ni.com/public.nsf/allkb/DC83E8CF04CE5AB686257539006131FE?OpenDocument&metc=MAXStopped...
Best regards
Abel Souza
Engenheiro Eletrônico
LabVIEW User since 8.5
(4,836 Views)
Yes, I did. The problems remains almost the same. After the service is started the Windows 8 give me the following message:
The service has been started but stoped imediatelly.
best regards
(4,833 Views)
What MAX version are you using?
Abel Souza
(4,831 Views)
The last one: Version 5.5
I am trying to reinstall the MAX by means of the NI-DAQmx Run-Time Engine 9.7.5 downloaded from (http://joule.ni.com/nidu/cds/view/p/id/4243/lang/en)
(4,824 Views)
On NI-MAX go choose on menu bar Tools>>Reset Configuration Data , it will restart MAX to original configuration and may solve the problem.
If it don´t solve please, post Max Technical Support Report.
http://digital.ni.com/public.nsf/allkb/271F252B4EF0A2E0862570E70056A1E4
regards,
Abel Souza
(4,818 Views)
I too faced the same problem and the solution you mentioned solved the issue. Thanks a lot..
(1,856 Views)
