Code Not Working Across Different Project Templates
On a traditional blank project, the code below works... I am able to get readings from my joystick. However, when I try to run the same code on a myRIO template, the code never gets to run because of error -363031 (from Highlight Execution).
How can I fix this?
Message 1 of 10
(5,002 Views)
Well, according to the Error Message, the myRIO didn't "see" the Joystick.  What makes you think that it can?  [I actually have a myRIO, but my Joystick device has a Device Number > 7, and NI's implementation of the DirectInput "hooks" don't go high enough -- I've filed a suggestion to fix this on the Idea Exchange, which you can find and Kudo if you want NI to look into fixing this].
Bob Schor
Message 2 of 10
(4,988 Views)
I think that my problem might have to do with the myRIO not being able to see the joystick. In the image attached, the Computer Joystick.vi under My Computer works. The same code, saved as Joystick RIO.vi under NI-myRIO does not run. The joystick is connected to the computer and not the myRIO.
Message 3 of 10
(4,942 Views)
Are you saying you still have the joystick connected to the PC, and you are wondering why the cRIO's VI won't run because it can't see the joystick on the PC?  A completely different target?
Message 4 of 10
(4,928 Views)
No, the idea is to keep the joystick connected to the computer (later to be used to control the myRIO which will be mounted to a rover over wifi). Can a My Computer vi be imported over to a myRIO vi?
(The code works when I plug the joystick into the myRIO but this does nothing to help me.)
Message 5 of 10
(4,923 Views)
No.
A cRIO can't see hardware that is connected to the PC.
Message 6 of 10
(4,918 Views)
Thanks for the response!
Message 7 of 10
(4,899 Views)
Background: I want to mount a myRIO to a RC Robot and control it with a joystick connected to my computer.
Is this possible?
I'm unable to use the joystick VIs on the myRIO project since the joystick is connected to my computer and not the myRIO.
I've tried creating a shared variable that contains the joystick information, but it will only work for VIs that are on My Computer and not on myRIO.
In the picture attached, Computer Joystick is the vi with all of the code. Variable 3 contains the output of Computer Joystick. Shared Var Test reads Variable 3.
"Shared Var Test" only works on My Computer and not myRIO.
Message 8 of 10
(4,877 Views)
Fix:
Create the shared variables under the myRIO target rather than under My Computer.
Message 9 of 10
(4,846 Views)
Accepted by topic author richardj1701
In order to keep the required hardware set up (joystick into computer & myRIO controlled via wifi), shared variables must be created under the myRIO target which is written into by VIs under the My Computer target. This allows data to be passed between different targets.
Message 10 of 10
(4,845 Views)
