Code as a Windows service fails to execute an active x control
I'm using labview to capture video from an AXIS video server. They provide an ActiveX control that I use in order to get the videos and control the server. My code is built in a dll in order to make it run as a service (as described in http://members.cox.net/kuanchen/lvservice/index.html). It connects to a postgresql database to sore metadata concerning the videos captured. When I run my code in labview, everything works. however, when I use the service I have coded. It still writes to the database but seems to fail to execute the ActiveX correctly and gives me no video recordings. Anyone has an idea ?
Thank's a lot
(3,325 Views)
Hi Milas.  I'll take a guess; does the user you are running the service as have rights to the ActiveX control?
Matt
(3,316 Views)
Thank you for your reply. I however think it is not that as the user running the service is the LocalSystem user. If you don't see any other solution, do you know a way I can debug this while it is running as an executable ?
(3,294 Views)
There are things that LocalSystem doesn't have access to, like a default printer.  Don't know about ActiveX controls,
which is why I am guessing 🙂
For troubleshooting, I would build a logger .vi that will just write a timestamped string or error message to a text file.  Sprinkle
the .vi around various areas of your code until you isolate where it is breaking.  Tedious, but it does work.
Matt
(3,292 Views)
Checked on ms website, it seems that it's ok for the LocalSystem user to run active x. However I found something. If the vi that contains the acitve x is not apparent then it seem not to execute properly. I will search on that direction and if anyone has an idea it would be great to propose it.
Thank's a lot
(3,287 Views)
