Code control systems for LabView
I´ve been searching on the forum for a robust way of doing code control using, for example, Github or Gitlab. For reference, https://forums.ni.com/t5/Reference-Design-Content/Getting-Started-Git-and-GitHub-setup/ta-p/3544824
I am extremely curious to know how you manage your code. Can you provide suggestions on how to create a repository so that I can keep different working versions of my projects?
(This should actually have been my first question before starting my project. However, I used a dumb-but-simple approach that I wish now to reform...)
Cheers,
Fl0
(3,063 Views)
Accepted by topic author Flonares
Related content,
https://education.ni.com/center-of-excellence/resources/450/session-getting-started-with-github-and-...
Before we get into source code control for LabVIEW, there are several YouTube videos on basics of source code control using Git, once you're familiar with the concepts, that can be scaled to LabVIEW with few differences.
Santhosh
Soliton Technologies
(3,044 Views)
I think SVN has a slight advantage over GIT for LabVIEW because you don't need to replicate the repository.  Because all LV files are treated as binary, the repo can get big in a hurry.
Bill
CLD
(Mid-Level minion.)
(2,972 Views)
Here's a good article from Delacor on the issue:
https://delacor.com/every-developer-needs-a-time-machine/
(2,960 Views)
In my experience, both SVN and Perforce have a good edge over Git since they track versions per file, allow single-user edits through locking, and centralize revisions.
Santhosh
(2,949 Views)
That's interesting, you see "centralized" as a plus?
I used SVN a long time ago, when I discovered decentralized VCS I quickly abandoned SVN.
I started with Mercurial and then went to Git.
I don't think I could work with centralized again, having multiple clones of the repo is such a useful concept.
Oh and I suggest reading this : https://www.joelonsoftware.com/2010/03/17/distributed-version-control-is-here-to-stay-baby/
We have two ears and one mouth so that we can listen twice as much as we speak.
Epictetus
Antoine Chalons
(2,909 Views)
I had my fair share working with SVN, Perforce and Git. For LabVIEW, SVN or Perforce workflows are better and especially for a newbie to source code control before getting into Git workflows as the paradigm changes and need a better software engineering mindset to effectively use Git.
Santhosh
(2,878 Views)
