Code generation error when implementing an accumalator
Hi everyone,
I am implementing an accumalator which implements X = X + Y where X and Y are memories of length say 5. Initially I write 5 values into X and Y using a for loop. Then I perform the addition inside a single cycle timed loop and store the results in a temporary buffer(another memory) again of length 5. In another single cycle timed loop, I copy the data from the temporary buffer to memory X.
I changed the arbitration option to never arbitrate for X, but I get a code generation error because of arbitration. Could anybody please tell how to solve this problem.
Prashant
(3,673 Views)
Hi Prashant,
Can you post your code?
Nitzz
(3,672 Views)
Accepted by topic author Prashant_dsp
Hi NitzZ
I figured out a way to solve the problem. I chose the "Never Arbitrate" option for all memories and replaced the for loop with a timed loop. Now there are no errors.
Prashant
(3,650 Views)
