Code interface node - .lsb generated but does not load
Howdy, i am using labview 6.1 and VC++/visual studio .NET 2003. i tried creating a simple code interface node to add two numbers. i followed the steps given in the "Using External Code in Labview" Manual. I made only one change, which is switching out "$(WkspDir)\$(OutDir)" (under custom build) with "$(ProjectDir)$(OutDir)" as the $(WkspDir) macro is missing from VC++. The build occurs successfully and i get a .lsb file. But when i ask the code interface node to load it up, it doesn't. The error description is, "Code Interface Node: object code not loaded." any suggestions? thanks in advance.
(2,980 Views)
This [link removed; article no longer available] KB describes what may be the issue. I hope this is helpful.
Ankita
(2,963 Views)
Thanks. will try it out.
(2,955 Views)
