Coding suggestion
Hello.
I want to know the method for creating a 'time-delay' before the data is passed. Suppose I have a 'Boolean' switch which is connected to a LED. If I press the switch, there should be some delay (say 30s) before the LED glows. Any help is appreciated.
Message 1 of 8
(5,345 Views)
Since I doubt you want to halt your loop for 30 seconds, look at using the Elapsed Time VI.
Message 2 of 8
(5,340 Views)
I have tried Elapsed Time. It is not of much help. I'd like to have a boolean control to the timer. Just like Timer On Delay (TON) block in PLC Programming languages.
Message 3 of 8
(5,334 Views)
Accepted by topic author Ganny
Hello Ganny,
I think crossrulz is right, the simplest way to do it is probably the Elapsed time function.
If i understood it right, you are looking for something like this.
Alban RCENTUM ADENEO
Certified LabVIEW Developer
Message 4 of 8
(5,306 Views)
This works well.Thanks AlbanR. Cheers.
Message 5 of 8
(5,291 Views)
Hello AlbanR,
I want to implement something like this.
When I hit a 'boolean' button, I want one LED to glow (say Red). After 30s time delay this Red LED should go off and another LED (say Green) should glow for next 30s and then similarly I want some other colored LED to glow and this should continue until I stop. Can you suggest me how can I implement this.
Message 6 of 8
(5,239 Views)
There is a tutorial available for LabVIEW State Machines that you might be able to use to do what you want.
Message 7 of 8
(5,234 Views)
Thanks cbuthcher. That was helpful.
Message 8 of 8
(5,225 Views)
